Conical inductors--still $10!...
On a sunny day (Thu, 23 Jul 2020 21:40:02 +0200) it happened Jeroen Belleman
<jeroen@nospam.please> wrote in <rfcp2h$edp$1@gioia.aioe.org>:
We don\'t want productivity, in as more new versions. We
want quality, robustness and durability.
Jeroen Belleman
Yes, what solution and programming languages are suitable
depends on the application hardware,
for example a firing solution for a micro size drone will
have to have the math written for a very simple embedded system, maybe even in asm.
The same firing solution for say a jet can be done in whatever high language makes you drooling.
I like Phil Hobbs link to the story about that programmer and his use of the drum revolution time..
https://www.unisa.edu.au/Media-Centre/Releases/2020/is-it-a-bird-a-plane-not-superman-but-a-flapping-wing-drone/
For better pictures:
https://robotics.sciencemag.org/
And apart from the number of bugs in the higher level version,
the failure rate also goes up with the number of components and chip size in a system,
especially in a radiation environment.
So fro ma robustness POV my choice would be the simple embedded version, not as easy to hack as most (windows??) PCs either, less power so
greener.
On Saturday, July 25, 2020 at 8:34:35 AM UTC+10, John Larkin wrote:
On Fri, 24 Jul 2020 23:15:27 +0100, Tom Gardner
spamjunk@blueyonder.co.uk> wrote:
On 24/07/20 19:09, John Larkin wrote:
On Fri, 24 Jul 2020 09:06:43 +0100, Tom Gardner
On 24/07/20 03:33, Bill Sloman wrote:
On Friday, July 24, 2020 at 4:34:25 AM UTC+10, John Larkin wrote:
On Thu, 23 Jul 2020 10:36:20 -0700 (PDT), Lasse Langwadt Christensen
langwadt@fonz.dk> wrote:
torsdag den 23. juli 2020 kl. 19.06.48 UTC+2 skrev John Larkin:
On Thu, 23 Jul 2020 17:39:57 +0100, Tom Gardner
On 23/07/20 16:13, jlarkin@highlandsniptechnology.com wrote:
On Thu, 23 Jul 2020 10:36:08 -0400, Phil Hobbs
pcdhSpamMeSenseless@electrooptical.net> wrote:
On 2020-07-22 20:14, John Larkin wrote:
<snip>
We don\'t need more compute power. We need reliability and user
friendliness.
Both of which are ill-defined concepts.
Executing buggy c faster won\'t help. Historically, adding resources
(virtual memory, big DRAM, threads, more MIPS) makes things worse.
For Pete\'s sake, we still have buffer overrun exploits. We still have
image files with trojans. We still have malicious web pages.
a tool that can cut wood can cut your hand, only way totally prevent that is to add safety features until it cannot cut anything anymore
Why not design a compute architecture that is fundamentally safe?
Instead of endlessly creating and patching bugs.
https://en.wikipedia.org/wiki/Z_notation
is an example of that approach. It doesn\'t seem to be ruling the world at the moment.
https://en.wikipedia.org/wiki/Hoare_logic
is a bit older.
The Viper provably correct computer is more recent - 1987.
https://www.cl.cam.ac.uk/archive/mjcg/papers/cohn1987.pdf
It doesn\'t seem to got anywhere either. I heard a bit about it before we left Cambridge (UK) in 1993.
Viper was interesting - a processor with a formal
mathematical proof of correctness. RSRE absolutely did
not want people to think it might be used in missile
fire control systems, oh no, never.
IIRC they flogged it to the Australians, then the Australians
noted there was a missing step between the top level spec
and the implementation. They sued and won.
There are three problems with any component that is
mathematically proven:
- most of the system isn\'t mathematically proven
- is the initial spec \"correct\"
- it is too difficult to do in practice
- jerks will still hack ugly programs.
I don\'t remember NewSpeak, the associated programming
language, ever becoming practical
No language will fix the mess we have. Serious hardware protection
will.
No, it cannot, for deep theoretical and deep practical
reasons.
A trivial example: there\'s no way that hardware protection
can protect against some idiot using addition where
subtraction is required.
Sure, the program will report his bank balance wrong. Or absent. But it
needn\'t crash the system, or inject viruses, or ransomware everything.
These are just different ways of having the wrong result.
That\'s not a theoretical example. A few years ago my energy
supplier set my monthly payments too low. When it noticed
that I was getting further behind with my payments, it
responded by /reducing/ my monthly payments. Rinse and
repeat another two times!
As for \"better\" languages, they help by reducing the
opportunities for making boring old preventable mistakes.
It should be flat impossible for any application program to compromise
the OS, or any other unrelated application. Intel and Microsoft are
just criminally stupid. I don\'t understand why they are not liable for
damages.
That\'s an ideal. Sadly, we don\'t live in an ideal world, and the people who promise us that we could, if only we did things their way, aren\'t to be trusted.
Many of them know that they are lying, and ones who sincerely believe their own claims are even more dangerous.
We are in the dark ages of computing. Like steam engines blowing up
and poaching everybody nearby.
John Larkin lives in his own personal dark age. He doesn\'t know much and comforts himself with the delusion that everybody else is equally miserably ignorant. His grandiose self-image prevents him from noticing that this isn\'t always true.
Bill Sloman, Sydney
<snip>
friendliness.
is a bit older.
will.
reasons.
damages.
Bill Sloman, Sydney
I actually designed a CPU with all TTL logic. It had three
instructions and a 20 KHz 4-phase clock. It was actually produced, for
a shipboard data logger. MACRO-11 had great macro tools, so we used
that to make a cross assembler.
When I was a Tulane, the EE department acquired a gigantic (basically
a room full) military surplus computer that used a drum memory for
program and data. The logic modules were big gold-plated hermetic cans
that plugged in. The programmer had to distribute the opcodes at
optimal angular positions on the spinning drum.
I have a book, IBM\'s Early Computers. In early days, nobody was
entirely sure what a computer was.
It\'s a fun book, and does a lot to deflate the Harvard spin, which is
always good.
The sequel on the 360 and early 370s is a good read too, as is \"The
Mythical Man Month\" by Fred Brooks, who was in charge of OS/360, at the
time by far the largest programming project in the world. As he says,
\"How does a software project go a year late? One day at a time.\"
Obligatory Real Programmer reference:
http://www.cs.utah.edu/~elb/folklore/mel.html
Cheers
Phil Hobbs
Burroughs programmed their computers in Algol. There was never any
other assembler or compiler. I was told that, after the Algol compiler
was written in Algol, two guys hand-compiled it to machine code,
working side-by-side and checking every opcode. That was the bootstrap
compiler.
Isn\'t our ancient and settled idea of what a computer is, and what an
OS and languages are, overdue for the next revolution?
The trick will be to get a revolution which starts from
where we are. There is no chance of completely throwing
out all that has been achieved until now, however appealing
that might be.
I know of two plausible starting points...
1) The Mill Processor, as described by Ivan Godard over
on comp.arch. This has many innovative techniques that,
in effect, bring DSP processor parallelism when executing
standard languages such as C. It appears that there\'s an
order of magnitude to be gained.
Incidentally, Godard\'s background is the Burroughs/Unisys
Algol machines, plus /much/ more.
2) xCORE processors are commercially available (unlike the
Mill). They start from presuming that embedded programs can
be highly parallel /iff/ the hardware and software allows
programmers to express it cleanly. They merge Hoare\'s CSP
with innovative hardware to /guarantee/ *hard* realtime
performance. In effect they have occupied a niche that is
halfway between conventional processors and FPGA.
I\'ve used them, and they are *easy* and fun to use.
(Cf C on a conventional processor!)
friendliness.
is a bit older.
will.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
Sure, the program will report his bank balance wrong. Or abend. But it
damages.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
On Friday, July 24, 2020 at 11:09:31 AM UTC-7, John Larkin wrote:
[ about computing bugs ]
will.
Like what? Error-correcting memory? Redundant CPUs and voting?
Nonrewritable firmware?
There aren\'t any hardware solutions to (for instance) facial-recognition that
unlocks a phone on seeing a face of a child who resembles his parent.
will.
will.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
Agreed.
But there are no silver bullets that can \"fix the mess we
have\". \"The mess\" is too many significantly different
messes, including philosophy and human frailties.
[1] e.g. what do you mean by \"correct\"
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
Agreed.
will.
Yup, and once we get into classifications, there are infinite
examples.
How would you classify a table that one or more people
are sitting on? Or (as in my dining room) a chair with
a potted plant on it?
Or, since dogs are four legged mammals, a dog that has
had a leg amputated?
And then there\'s the whole emerging topic of machine
learning \"adversarial attacks\".
https://medium.com/onfido-tech/adversarial-attacks-and-defences-for-convolutional-neural-networks-66915ece52e7
will.
examples.
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
Check out Qubes OS, which is what I run daily. It addresses most of the
problems you note by encouraging you to run browsers in disposable VMs
and otherwise containing the pwnage.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
Principal Consultant
ElectroOptical Innovations LLC / Hobbs ElectroOptics
Optics, Electro-optics, Photonics, Analog Electronics
Briarcliff Manor NY 10510
http://electrooptical.net
http://hobbs-eo.com
On Sat, 25 Jul 2020 14:51:38 -0400, Phil Hobbs
always good.
Cheers
Phil Hobbs
compiler.
that might be.
friendliness.
is a bit older.
will.
reasons.
damages.
Cheers
Phil Hobbs
That sort of thing is just another layer of kluge. It\'s sad that it\'s
necessary.
John Larkin Highland Technology, Inc
Science teaches us to doubt.
Claude Bernard
problems you note by encouraging you to run browsers in disposable VMs and
I did.
It doesn\'t like Nvidia graphics cards, and that\'s all my
new machine has :(
snip
damages.
That\'s a bit much. For one thing, there\'s no reason for anyone to ever
release any software that exhibits any of the top CVE pathologies,
regardless of tooling or methodology.
We didn\'t - those with whom I worked. We designed against it, coded
against it and tested against it. I have no evidence of *one* actual
defect in anything I released from about 1989 onward.
I\'m excluding \"yeah, you did this, and I meant that\". Those are
perfectly understandable requirements mistakes.
What you see is the population of developers doubling every five years.
Well, I hate to be that guy, but it probably takes more than five years
to reach the journeyman phase. If I count college, it was about that for
me.
So what we do is move the goalposts and redefine \"work\" to mean
\"knitting together frameworks into deployments\".
Specifically:
They had a lot of co-conspirators, then. Perhaps you don\'t recall, but
the sheer change in cost created massive opportunity once PCs got
big enough to do real work. And nobody paid anyone for rigor in the work.
The value created was substantial.
Electricity-as-power has a much higher historical body count.
Les Cargill
